Outlaw Construction
Rob,
I am going to put a Webra 32 in mine. Your setup should be sweet. I too was alittle cautious when I started to build the plane suspended in the frame.
The dotted lines on the rudder are the locations for the alignment pins that keep the rudder straight at the seam since about a 1/3 of the rudder is over the hatch. Is that what yout talking about? or is it the 3/16 inch slot your going to make in the rudder mount? I measured and scored mine before gluing it in. The slot must be right on center. Hope this helps, Pete
