Old 09-14-2002, 06:42 PM
  #42
Rocketman612
My Feedback: (84)
Rocketman612's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Finished Sheeting
Well it's looking like an OUTLAW
I did not run the trailing edge sheeting up to the rudder. Instead I ran sheeting along the rudder with some added stock along it's length for more support. Almost done with the rudder (alot of sanding to taper it to 1/16 in at it's trailing edge ) I have already sanded a 45deg edge on both sides so I'll get a 90deg movement. will do the same for the elevons and the wing trailing edge. I did mark, drill and place the motor mount on BEFORE I finished the sheeting. Also fuel proofed the tank area with 30 min epoxy thinned with alcohol.
Rocketman612 is offline
