Outlaw Construction
I did not put in the Doublers between both Rib #1, until I had the motor mount squared away... But after that, I put them right underneath the diagonal spars, glueing the spars to the doubler.
Before sheeting the leading edge, I also added another 1/16 sheeting to the doubler in front of the spars, to eliminate the 1/16 gap underneath the sheeting...
Pete and I did the rudder different.. I notched out completely the support and put the rudder straight through it.. then connected the tailskid right to it solid..I think pete actually followed the directions!
