servos spazing!
i hope you guys can help,
my elev and rudder servos start oscilating on a full charge 5.7v. but it seems when the batt starts to settle 5.3v the oscilation stops. when the oscilation on the rud and elev is going on the other servos are fine, which leads me to beleive its not a freqency problem. the servos are jr537 standard and r700 rx, both rud and elev have 18" heavy duty extensions and the batt is 2700nimh. the servos do have alot of time on them along with rest that arnt causing any problems?
is it because standard servos are no good for high volts, or that my servos pots are worn or dirty!
also the antenna is ran no where near the servo extensions, its ran to the wing tip
