PCM9X Range
Hi
I would like to know what is the distance btween the PCM9 TX and a PCM RX with the antenna retarcted?
I tested 50 steps there was no signal, once the antenna got extended it was fine.
Is there any KNOWN ways to test the range? ( range check procedure )
Thanks 'n' Regards
