RE: The Badius Owners Club
Brent,
Thanks, that is exactly what I thought, but I figured I'd ask anyway. By having the servo horns to the outboard side on each wing will give me the opposite direction.
Hey Diggity Dan,
The MM motor looks real nice for the cheap bucks, has replaceable brushes and weighs 7.0 oz
compared to the stock motor 7.8oz.
The Great Planes prop is a nicer quality than the stock prop also, and has a bit wider blade area. I think the prop shaft on both is the same, but I will mic them up later.
Those Kokam 1500's that I bought are pretty small, so if needed I could hook up three in parellel and get 4500mah, that should give me @8C 36 amps
I will know better when I get the batteries charged up and get a prop on it. I can test on the bench for static amps.
