RE: Futaba module retuning
Furthermore, how do you explain the fact that it is ok to rotate two tiny flimsy dialers to change channels in a synthesized module but it is "against the law" to change Xtals in a regular module? How can one be sure that the dialers are 100% accurate? Are you sure that a mechanical action (rotating the dialers) can guarantee a non-mechanical result which is the change inside the module's electronic circuitry??
