RE: 9C and flapperons, need a little help..
It is not that difficult, you have to set up a mix for each servo and also for each position, ie set up channel on on a mix to move a little bit, then assign it to switch c middle, then do it again with more throw and assign it to switch c down then repeat for channel 6. this should work but is a little cumberson ro program.
Terry
