RE: Help - Older FP-6NFK broken switches
GCL,
Just make sure that the lead that is connected to the center terminal on the old switch is also connected to the center terminal on the new switch. The other two don't really matter. The only thing that will happen is the flaps will operate in reverse if the outside wires end up reversed. This is solved by using the reversing switch.
George
