RE: OV-10 Bronco (81" Uravich ARF)
Here's some info on the Bronco. I did install flaps but have not got enough nerve to try yet. It does land easliy without. I did not install retracts. Instead I put in heavy duty Fults gear(see photo) I used the 60 degree bell cranks but if I had it to do again I would put a servo in the tail. You can see I have the tail section bolted together and the way I transport to the field with the bar across the nacelles. Works great since it will not fit assembled in my suv. It means I have three pieces to transport, fuse, wing and nacelles. No problem. My two OS. 61 FX have a 13x6 APC turning at 13,500 rpm. I thought it might be a problem to get them running a same speed but it was not. My advice get two reliable engines.
