RE: ESKY 3D -TAKE OFF PROBLEMS-HELP PLS
Billyray,
Was wondering if you got your Optic 6 yet and whether or not you've tried it with your HB2. Just got mine today and after quite a bit of tweaking finally got it working.
I got the QPCM version and after setting the TX mode to PPM (FM) and the Spectra module to 54 (72.870) it was finally able to communicate with the receiver. I then set the programming to Heli and the swash to 120 deg. and then reversed CH's 2 and 6. This got everything to near normal except that when the throttle was at 0, I hear the servos "stuttering" as if binding. I then set the EPA down to about 39% before it went away.
On a different post, I had asked if anyone knew the proper pitch for a HB2 but I took the Optic 6's recommendation of about +4.5 at mid-stick (hover), this along with some pitch curve adjustments and now I notice that at full throttle, I'm no longer seeing reduction in speed (guess due to over pitch).
Still have some tweaking to do, will report back tomorlo.
Let me know if you have any tips on setup, etc.
Thx!
