RE: Vmar Easy 3D Conversion
I finally got around to installing the landing gear on my Vmar Easy 3D.
To improve the look, I added some Hangar 9 Funtana .90 (HAN2683) wheel pants and mounted them using the stock supplied hardware with a set of Sullivan (888) 5/32" Wheet Pant Brackets.
The gear mains simply screwed into the pre-drilled holes on the fuselage bottom. The tailwheel assembly simply pressed into the pre-mounted brass tubing on the rudder and screwed into the pre-drilled holes on the bottom of the tail.
