RE: How do you mount fuel tank on Dust???
The easy way out is to remove the tank and replace it with a bubble-free fuel system.
The DD and Whiplash tank installations were both pretty tight. With higher rpm engines, yes, fuel foam is an issue.
Can you get the existing tank out without destroying too much?
