RE: Which of these two receivers would you use?
Accoring to Berg, you can use their receivers in any plane.
XJet, thanks for the info. I happen to already have both receivers mentioned, and, the PCM is actually already installed. I think I will stick with the Futaba PCM. Thanks.
