RCU Forums - View Single Post - AXI 4130 w/Jeti 77esc?
Old 02-11-2005, 01:00 PM
FlyinTango
Default RE: AXI 4130 w/Jeti 77esc?
Hello Greg,
Thank you so much for your advice and input! I measured my prop clearance and found there is only 13 inches from the center of the nose / prop shaft area, to the ground. It is a tail dragger, so I guess that limits my prop size to about 20 inches, right? Plus, by the time I purchased the AXi 53 series motor, esc and a 10s Li/Po pack, I would be so far in debt, I would need binoculars just to see my bottom line at the bank. I think before I did that, I will just buy a Saito 1.50 or 1.80 and go with the glow engine. Whoa! I can't believe I wrote that on an AXi 4130/16 thread. Please forgive me guys.
I am tempted to just buy the AXi 4130/16 and try it in my Air Tractor and see what it does with the APC Electric 17x10 or 17x12 2-blade prop.
Greg, which do you think is better for the AXi 4130/16, the Phoenix 60 amp esc or the Jeti 77 Opto esc?
Thanks again!
Tango
