RE: Hitec Optic 6 vs. Eclipse 7
Apparently it only occurs if you use aileron differential and/or a whole snotload of negative subtrim on throttle.
I'm still using my O6 on a couple of 3D profile ships with separate aileron servos and have no problems -- bit it would be nice to get it fixed *just in case* I forget and inadvertantly configure a bird such that it triggers the problem.
