RCU Forums - View Single Post - f-22 speed plane help wanted - my engine has arrived
Old 02-15-2005, 03:01 AM
Hotrodkid
Default RE: f-22 speed plane help wanted
i would like to stay on the high side of your engine reccomendation, as i was origaly thinking 60-70 range ... but since my thrusthp wont install (ms-dos errors for some reason) i cant play around w/ props to find what would , hypotheticly, be a good prop, any suggestions ?
this is one of the engines i was considering... as it has a rear exhaust, and the built in fuel pump would be a nice feature also : http://www.rcuniverse.com/market/item.cfm?itemId=76299
due to the need to have clearance around the prop for structural members, i was hoping that i could use a 3 blade prop instead of a 2 blade prop
it would seam that youd be able to use a smaller diameter prop if you used a 3 blader
yes no ?
i dont think the fuse will add much left either, for this model im just going to use straight sides and the bottom, and then the top will be one simple curve as seen below
(9 inch prop shown)
ID:	229631   Click image for larger version
