RE: Stinson
Hi adolf,
Am not familar with the ST's dimensions, but the space inside the cowl is quite large.
The distance from the firewall to the front of the cowl is about 6-1/2 inches, the cowl's inside rear diameter is about 10 inches, and the cowl's inside front diameter is about 7 inches. I only had to cut out a little of the cowl bottom to allow for my Q35's head fins. Would not think you'd have a problem fitting the ST inside.
