RE: TO: GREG COVEY (...OR anyone else who knows)
FlyinTango,
You can use the spinner if you make alternate means for the air to get in. For example, you could put one or more air scoops on the sides or underneath the motor. With a little creativity and careful prep work you could make them look like they were meant to be there.
Running 54 Amps to the motor, I would not recommend flying with no airflow to ANY motor.
