RE: Horizon Hobby Yak 54F, anyone fly yet?
Okay, I need some help!!! I've framed up the plane and have a new Outrunner 400. It says to reverse the shaft by releasing the set screw and move through the stationary part of the motor. I was able to loosen the screw. In fact, I completely removed it and am looking at the shaft through the hole. I can't move the shaft. It has some form of Loctite or something on the set screw. The thing is bound down where I can't move it and I don't want to damage it by really "cranking down on it". If I can't get it fixed, can I just run the outrunner on the outside in the normal shocky way? As you can tell, I'm new to electrics!
Thanks in advance for your help...
