RE: The Badius Owners Club
If if upgrade to a speed 400 motor, why would I use a lower voltage battery than the stock.
Also, If I order a new Fuse, does it come with the servo and battery houseing?
Also, I seriosly doubt I can fix the metal washer motor mount. I guess I could make my own with a real metal washer? How do I line up the motor in the fuse? The motor just seemed to be resting in there. Was it originally glued?
Thanks for the advice.
