RE: Can i install a larger fuel tank on a cox .049
Don't use any thread locker! Tightness is what keep things tight. If your engine is vibrating, then either replace the prop or try to balance it. Make sure the engine is mounted securely too. If you cinch it up good, the glow plug shouldn't come loose.
