RE: Aerobird tail adjustments
If the boom and fuse has not been damaged, then level with the boom should be close enough. when you fly it, if you have to trim up a lot or hold the stick back to stay level, then adjust the tail to tip down a little. The opposite if you have to hold the stick forward to stay level.
Good luck
