RE: 8103 throttle curve setup
OK, After reading all the posts & suggestions, I tried setting the throttle curve on my 8103 (non DT) on my DA50 with 23x8 on it.
However the values that I have been able to set (to get the required throttle reponse) is VERY differennt from what you guys have recommended
I'm using P-Mix# 1 (Throttle->Throttle)
Point | IN | OUT | ENGINE RPM (Appx)
L | 0 | 0 | 1500 (IDLE)
1 | 25 | -30 | 2500
2 | 50 | -60 | 4000
3 | 75 | -80 | 5000
H | 100 | 0 | 6500 (WOT)
I understand that Gas Engines behave diff from Glow & generate 3/4 of their power in the first 1/2 opening of the carb plate/valve etc.
I just wanted to verify if anyone else has set theirs on a DA50 & what settings/values are they using?
Also is there any drawback of using such large values? (Servo travel is 100% both ways)
--Arvind
