RE: ParkZone P-51 Mustang RTF
Hey everyone, pull the cowl and the gearbox and check the motor screws mine came loose after 10 flights and the washer got between the gears and stopped the prop. This plane will not glide very well and I nosed it in from about 10 feet broke the prop, cowl. spinner and the elevator. My J3 Cub did the same thing but it just glided to the ground.I think if the washer had not got between the gears it still would have flew ok, but with no prop it came down hard. I was just getting used to high speed passes right off the ground, this plane is fun.
