RE: HiTec Electron 6 rerceiver
I was just reading about this last night since I'm setting up a Mini Funtana, I believe it said you can change it to channel 5. If your manual is the same as mine, look at page 43, and I believe this is where you change it from 6 to 5. Good luck. Ohh I didn't really read your post correctly...the battery slot is channel 6, but you can change your left aileron to channel 5 if you wish.
