BVM Super (Balsa) Bandit
Also, since the screws that hold the servo to the black plastic part of the mount protrude slightly through the plastic part, they can catch slighty on the block during removal.
This is a truly minor detail, not an actual problem, but here's the approach I've used on all of the Bobcats I've built, as well as now using on the Super Bandit... simply use a 1/16" cutting bit to route out a small groove at the point where the block and those screws would meet - now the ends of the screws slide up the groove during servo removal or insertion.
