RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics - Videos - L@@K
Wayne,
Thanks for the feedback on wheel/tire situation--I will check out your recommended solution. Reutilization of my Sullivan wheels on a Cub is a non-start, however, as I already have the needed 4" wheels for my 1/4 scale Cub.
To explain the mod CA recommended, and what I achieved, it seems clear that very little "wobble room" was available once the wheel/tire combination was mounted in the optional gear. Once chamfered there is ample room to wobble. My added mod of installing bearings on both side of the hubs makes the wheel more stable on the axle (the replacement titanium axles are a thousandth or two larger in diameter than the supplied steel axles, and the larger diameter may also help).
Again thanks for your insight. I appreciate it.
VR
Jack
