RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics - Videos - L@@K
Jack, What gear are you using on yours,the factory gear or Sierra Precision ? If you're using the factory ger I have a suggestion you may be interested in. The C/A manual says to use the "small wire",whatever that is to keep the spring strut from falling out when there is no weight on it. I modified mine to have a slot in the strut piston with a socket head cap screw thru the aluminum strut barrel that rides into the slot I milled into the strut piston. If you're using the factory struts ,e-mail me and I'l talk more about it. I got my wings installed today and its on the gear and will install the flying wires next. Hope to have it flying in a couple of weeks or so. Wayne
