RE: GSP Zero
Hi,
I am just about ready to assemble the Zero and was going over the instructions and parts. I think I may be missing one of the smaller 6mm dia. aluminum joiner tubes and was hoping someone who has this kit can tell me how many of the aluminum joiner tubes they have and how it goes together. I have three tubes. One larger 18mm or so in dia., and two smaller 6mmx40mm tubes. I believe the smaller 6mm tubes are needed for the Horizontal stab to fuselage connections, however it also looks like from the instructions step 5 when joining the wing halves together that you need to use the large 18mm tube, and another smaller 6mm tube. This means I'm short one of the 6mm tubes! The kit does include some wood dowels, but those I believe are for the pushrods, not the wing joiner. Anyone with this kit know how many tubes it comes with and where they fit? Instructions are pretty bad, but do show a 6mm tube for step 5 the main wing halves. But do not show which tubes exactly fit the stab attachment step 13 and show 12mm holes to be drilled in the fuse for the stab??. Seems they need to be the smaller 6mm tubes though, which means I don't have enough to go around....
Other than this the kit seems to be of excellent quality, and can't wait to get started on the assembly.
