RE: Futaba Receivers
The 148dp is the replacement for the 138dp, which both are 8-channel pcm. The 149dp is 9-channels and is pcm. If you are deciding which one to get, you should get the 148dp because it is smaller and lighter than the others. I have never had one fail.
just my $.02
