2nd DD test flight
There's an easy way to see if you have the right carb. Measure its bore..ie, the diameter of the hole. Should be right around 9mm as I recall. Just put a ruler w/ mm across the opening and read it.
Also to eliminate any fuel tank/line problems, you should put the engine on a test-stand if you have access to one.
Carl
