RE: Aileron Servo connections to Receiver...
OK, I think I'm getting it now.
I plan on mounting the servos on their side inside the wing (to get them to fit in the wing) and the servo arm is the only thing sticking out of the bottom of the wing. So if I use a "Y" harness, as long as they are mounted opposite each other (as in both of them mounted so the top of the arms face to the wingtip...or both mounted so both face the fuselage) they will automatically move opposite each other? And if I mounted them so they were oriented identical (as in both facing the same side of the plane) then they would both go up or down together?
As an example...
Servos will be mounted as such (facing the front)...
L - Wingtip __________ [-__ {+} __-] __________ R - Wingtip
Where [-__ is the servo mounted horizontally and the servo arm [ is vertical...and {+} is the fuselage.
Mounted like this... [-__ [-__ they would both operate identical (both going up or down together) and...
Mounted like this... [-__ __-] they will work opposite, correct?
