RE: Cheap RC Scanner
Well, I think so. You can set the Uniden to search only your desired Tx frequency, say plus or minus 10Khz in 5Khz increments over and over again to look for interference. I believe the search rate is 10/sec. Or you can just set it on your frequency, cut the squelch down and listen to what you hear.
