Receiver fried from switch
My new PCM RX fried today I went to charge my cells in my new predator gasser 4 tanks now with a triton charger and using a Cermark switch. plug the plug backwards I forgot witch way it goes in hit the charge button the volts went to 40 or so volts then an error come up no battery so ok turn the plug around hit the charge button then it stared to charge good when done I turn on the heli nothing the RX is fried I replace the rx with a spare works fine my fried RX smells burnt so now I’m out $100 for a RX I never had this happen before with any type of switch I’m so mad
any of you had this happen
thanks
Atvracer
