Whiplash Crash (Was Whiplash Control Throws)
Steve,
When you get the plane back in the air do a full throttle pass and cut the throttle to idle while pulling vertical. You will be amazed how high this plane will go. These planes are pretty clean and cut through the air well except when high bank turning or at a high angle of attack.
You mentioned you were already going 120mph, at 120 you should be able to do a complete 3/4 loop/roll to land. If you aren't traveling very fast, then just point the nose down and take the walk.
Mark M.
