ORIGINAL: exeter_acres
I label mine as well...big label..
and if the plug was reversed wouldn't the ailerons be reversed too?? it was just the flaperon/spoileron function that was reversed..
but yes... attention to the details is important
I think you can setup up the aileron servos mechanical linkages such that they will work the same either way you plug them in.
