RE: Using a Deans Antenna on RX
NO.
You cut the antenna to leave a length of 4 to 10 inches. It is not for mounting purposes per se - has to do with how the base loaded antenna plus the remaining antenna wire length is "seen" by the receiver. Normally I cut mine to 6 inches.
Dan
