RE: Trim setting changes when going to high rates
The pot is the source of the signal whether you're on high or low rates so that's a wash. It seems more like a tx glitch than a worn pot. Almost as if your high rates is treating the trim as an input signal from the stick and amplifying it, hence the movement.
