RE: Hobbico Superstar EP
The tail assembled very easy without any glueing. The Superstar RTF Select comes with the control horns premounted. The horizontal stabilizer slides into the rear of the fuselage first and then the vertical stabilizer locks both pieces to the fuselage. The threaded rods are secured with washers and nuts.
To attach the control rod, first remove one screw from the control horn and twist it to accept the "Z" bend in the rod. Secure the control horn and you are ready to tighten the screw on the servo arm quick link. I decided that my control rods were a bit too long so I cut off an inch.
