Hitec Eclispe 7 Dual elevator servo's solution
The Hitec Eclispe 7 doesn't support dual elevator servos on seperate channels, a glaring weakness in this transmitter, in my opinion, one solution is to use a reversing wye or servo reversing extension on one servo, another solution which I installed today on my U Can Do 60 is a JR Matchbox, while JR states that the matchbox hasn't been tested on other brands of radios they say it should work and so far for me it works fine, the big advantage of the Matchbox over a servo reversing lead or wye is that you can individually adjust each servo and get matching elevator movement. I'm using it with an Eclispe 7 and Hitec QPCM receiver with Hitec 625 servos on each elevator half.
