Bad servo can cause this. I would replace the one that's slow in one direction. Sounds suspicious. Make sure the ant. isn't near anything. Good range check. etc. I had a shorted out servo in the Zero. Locked up everything. Went in at full throttle from about a hundred ft. Popcorn
