RE: Having servo problem?
I get Twiching when either my Transmitter is off or if im near overhead wires RF interference,Also if your near Florecent lights they throw off RF too.Now if its none of the above it could be from Truckers Cb use if there's a local hyway near you.It could be from just the planes wiring,mabey the batery lead is runnig along side of the antena wire.
There can be alot reasons,But to find the exsact cause can be frustrating.If your able to change servo connections on the receiver this may help you to see if its just the servo or if its the receiver. I have a chatter in one of my flap servos when its activated.
But this due to damage to the servo.When I tried to wire it up to work in a opisite direction.later I found out they have a very expensive wire to do this.They sell a channel checker to see if your channel "frequency" is in use by some outher source,It cost about
40.00 dollars,I would like to have one of these too.
