RE: V-Mar F-4 - First Opinion out of the box...
If you are careful with how you store and handle the model, you will minimise any hanger rash, and it will always look good. Where the covering has started to lift here and there I have used cyano Zap-Ca to glue it back down. The fixed undercarriage can handle the less than perfect landings that happen sometimes.
My F-4 has also had a crash, which wiped out the vertical fin and canopy. I managed to get replacement parts and all is looking and flying good again.
So ...Yes, I would probably consider buying another VMAR propjet ...
