ORIGINAL: olstoney
As mine has not arrived yet, I cannot give any advice here. Can the factory supplied on-off switch be replaced with one having a charge jack incorporated such as the Electrodynamics HD, JR HD, MPI or similar? Does anyone have any input to offer on the questions I posted previously[
Sure you can replace the switch with a dual function switch and charge jack. I have an MPI switch/charge jack unit with an LED voltage indicator that I am going to put in mine.
There is also a precut opening on the right side of the fuse to mount the charge jack, just cut the covering and buy a charge jack mount kit. This side is in the exhaust stream though as others have mentioned.
-Blee
Naperville IL Propmasters club
