RE: I screwed up the mix now what do i do?
You can try heating it up a bit. Sometimes heat will help if you were close enough on the mix ratio. Basically, consider it an oops. Epoxy must be mixed correctly... that's the one catch.
Was it too little hardener? Too much hardener? Not enough mixing time?
-David
