RE: EKSY HoneyBee CP2 6CH Electric Heli Help!?
also make sure your tx throttle is all the way down before you turn on your heli. most have safty cut offs so if it's on above off it won't turn on. I just had this odd feeling that the throttle switch is inplace the wrong way, try (on the back of the tx) flipping the switch labeled "throttle" if I'm right (about it baing wrong [&:]) when you thought it was at off it was on max making the safty cut off go wrong. to test this theory set the heli in an open space and put the throttle to max turn on the rx (carefully making sure the blades won't hit you) if I'm right when you push the throttle down it should speed up, if not it won't do any thing at all (or it could turn on quite suddenly)
