Speed on the cheap
Is this a weight issue, or are you saying that foam flies better, even if weight is the same? If so, you're suggesting foam has magical properties. If it is a weight issue, this is such an overpowered and light rocket as it is that the minor weight savings a foam wing has does not justify the extra expense and work of dealing with foam. It does have to be covered in some fashion doesn't it? Coro does not. Really I just wanted to suggest an interesting and cheap design to those who want something very fast and very agile. But of course, within two or three posts as usual, someone comes along to snub it somehow, and now the thread is meaningless. Goodbye.
