ORIGINAL: Dealspeed
.......so i decided to rebuild all of them with the metal gear sets.............
.........It made the strangest noise in high speed passes like a low pitched wistle almost, anybody know what that may be ??
You may have flutter that stripped the gears in your servo. Metal gears wont help if that is the case. The high speed pylon guys usually use nylon gears.
