RCU Forums - View Single Post - Monster MGT Owners Whats involved in dropping a mach .26 in this truck?
Old 10-01-2005, 10:00 AM
benifur
benifur's Avatar
Default RE: Monster MGT Owners Whats involved in dropping a mach .26 in this truck?
It'll drop in. Do you have the losi exhaust? you'll need a pipe the MGT it to small. If you have to get a pipe get the RDLogics it works good on the Mach and it comes with the header ( like the losi) so you can run it up the side. If you got a extra 40 bucks or so get yourself the sportwerks carb. w/ 9mm. insert. This combo of engine carb and pipe work extremlly well together The mach collet is short. I would use the MGT flywheel and clutch . I like it I just bought the stuff to put it on my basher LST. I would like to see all manufacturers start using vented fly wheels. They have to help cool a little after all it's a fan. The mach should make the MGT fly pretty good.
